When a new design is created, your design flow is to get us right into the design mode (which is great) but I’d like a way to either:
name the design in the process of opening up the design window (not as ideal)
naming the design while ‘in it’. Perhaps top right just have the name of the design that can be tapped and edited. Initially — would be ‘unnamed’ or blank, which is the default state of what we have today. Tap it and name it “wonder-widget XYZ” (or whatever) and its done. Would also allow designers to start from a base design and either rename it or create a duplicate design (through a pop up ask of whether the designer wants to simply rename or create a ‘new’ design). Today, one has to get out of the design and edit or duplicate the name in a clunky design flow.
Thoughts?
I would like something simple and within the design UI vs the outer project shell
