No Offset Edge in History
I searched the forums and I came across someone who had said the offset edge was not parametric. This was in September of 2023. It was a known issue and was proving to be more difficult to work with. I started working on a project and thankfully did not get too far into it, but the first step I did was create an edge offset. I had done some extrusions then went back to make it slightly larger using history, but offset edge was not there. I’m assuming this has been removed due to the complexity? If so, is there an estimated time of resolving this issue?
No sketch operations show up in history by design.
