Offset edge is not parametric
If, in a sketch, I use the offset feature, the resulting lines won’t adapt when the edges (that were used to create the offset) change due to a modification of the associated solid. They should.
François
Hi @NovumInitium , we are working on it. It will be available in a few weeks.
@Istvan been a while since this was a few weeks out, any word on if this is still coming soon?
I assume everything got pushed back since History-Based Parametric Modeling wasn’t released late 2023. :slight_smile:
It’s getting ready, it has proven to be a harder problem than we thought.
Now in April and still not working…
Indeed, unfortunately it takes longer than expected.
