Object displayed in transparency
I don’t know what I did to it, but all of a sudden whatever I open, draw on the ipad turn into transparent objects… even the old ones I opened again is displayed in transparency. Can any one help to set this properly again?
Hey - please check if you have “Show Hidden Edges” turned ON. See pic on where (top right icon in the modeling space)
If it’s ON, your all hidden edges will be shown, thus giving a transparent effect. It is a global setting, so every workspace of yours should be back to normal once you have turned it OFF.
Hello I am having the same problem, I noticed the drawing plane moves as well.
Is there away to go back to the old way?
Thanks in advance!
Every body that would block the visibility of the drawing plane becomes transparent.
The solution is to select the plane before you start sketching (double tap, hover + space, or double secondary click on it).
We are planning to improve the behaviour to make it clearer.
Could you make a video for the iPad on how to do that? Thanks !
Sure, here is a short one. The red dots are the finger taps.
