Object in imported drawing
I created an object but I was inside of a sub drawing and accidentally created it a a part of the sub. How can I move or copy the object up to the main design?
You specify what you want to copy and with the project command you can project it where you want.
Solution
My problem is not copy or move the object but in where it is located in the object list. I\The Button is currently inside the folder “imported assembly” and I want to pull it out of that folder and put it at the top level so that I can delete the “imported assembly” folder.
Hi, Maybe this is what you need.
Awesome! That did it :slight_smile: Thank you!!!
Welcome to the community! Enjoy it. :slightly_smiling_face:
