As per Facebook……MOVING BODIES
In the new update, when I am moving body- part, the Center point of the XYZ is stationary. To be able to reposition the moving point to an other part of the object I have to de-select it and click to an other are to activate the move. In the old version as long as the object was selected- highlighted I could move the XYZ anywhere around?! Correct? PS. I understand the reason, but find it as additional steps. Specially when working on iPad. Thanks.
Hi Edward,
I find it easiest to move the “gizmo” (the name for the XYZ thing) before doing a move/rotate. That way I am certain that I have it anchored for the correct move or rotate. Sometimes I’ll move the gizmo just to get it closer to where I may need to zoom in.
Thanks will try
