Hey guys, this is a bit off topic but figure someone here may be able to help me.
So earlier while working on a project in Shapr3D I found I screwed up a lot of measurements and decided to revert to the oldest known good model I had exported.
Low and behold to my dismay I realized it had only been .stl file I had saved and exported. Obviously not something I could re-import too Shapr3D.
From what I understand you can use freecad trial to convert a .stl File. back into a .step, the issue is I already tried this couple months back and used my trial. Does anyone know a way I could convert this .stl to get my file back to work on Shapr3D?
