I had issues with offset tool where it creates a new sketch and other times offset lines is on the same sketch.
I now figured out if you select the face of the sketch the offset creates new sketch.
If you select just the lines offset stays in the same sketch.
Looks like a feature but shouldn’t offset just stay on the same sketch?
TheBum
2
I’ve learned to use the sketch item in the left sidebar for selecting sketches for almost all operations.
Here is what happens, 2 different behavior for offset.
Offset starting from Sketch Face, need to project the offset back to the original sketch.
Offset starting from Sketch Edge, offset on the same original sketch.
I have also found this doesn’t happen all the time.
