Options for the Arc Tool
Almost every time I use an arc, it is a 3 point arc. Having only the option that you have is almost useless for many arc applications?
Having a 3 point arc and maybe a center point arc gives the user much more control. Every other CAD software has these options and adding it to Shapr would make a huge difference for some of us.
Yes, what should take me a few seconds becomes a task of work-arounds that takes much more time.
