Parameter Cards: what we heard, and what’s changed in 26.200
Hi everyone,
Over the past weeks you’ve given us a lot of feedback on Parameter Cards. Some of it was hard to read, but we’re glad you wrote it anyway. Several shortcuts didn’t work reliably, some flows needed more clicks than before, and some options were harder to find or had moved. We went through your posts, picked the top five issues that came up most, and fixed them in 26.200.
This post covers what changed and what we’re working on next.
The five issues we fixed
1. Card docking on iPad
Cards can dock into the top or bottom slot of an open sidebar. The sidebar resizes to make room and returns to full height when the card is hidden or moved.
2. Switching modes on the gizmo
You can now change these modes on the handle, without opening the card:
  • Extrude: Switch between One-Sided and Symmetric.
  • Chamfer: Toggle Equal Distance or Two-Distance directly from the primary handle.
  • Fillet: Toggle G1 / G2 directly on the handle.
  • Scale: Quickly switch between Uniform and Non-uniform scaling on the gizmo.
3. Extrude “To Object” by dragging
If you drag the extrude handle off-axis onto another body’s face, the extent switches to To Object and snaps to that face. If you release over an invalid target or empty space, the preview is cancelled.
4. Seeing what the tool is doing
  • Shortcut cycling: when you cycle an option with a shortcut (for example Extrude types or Chamfer/Fillet methods), a small bubble now shows the parameter row, the selected option and its icon.
  • Auto labels: parameters that evaluate automatically are now labeled, for example “Auto (Union)” on extrusions, so you can see what Shapr3D chose.
5. Shortcuts and 2D/3D tool launching
Some shortcuts didn’t work reliably, and tools with both 2D and 3D versions (eg. Move, Scale) made you choose a variant before you could start. These tools now wait until your selection makes your intent clear, then pick the 2D or 3D variant. Inside a sketch they default to 2D, and in modeling they default to 3D. The default shortcuts now live on these combined commands.
Bonus: clearer Project command names
Several commands were confusing, so we renamed them:
  • Imprint Edge → Project As Edge
  • Project (Sketch) → Project As Sketch
  • Project (File) → Import Project
Using Project on a non-planar surface now shows a hint pointing to Project As Edge.
New in this release
  • Sketch Fillet: You can now apply fillets between arcs and lines by simply selecting corners or connecting geometry.
  • SVG Import: Bring vector graphics directly into your workspace.
What’s next
  • More fixes based on your feedback are in progress.
  • Next release: Sketch Slot and Sketch Extend
  • Later this year: a first milestone for Threads & Holes
Tell us what you think
Please try 26.200 and tell us what works and what doesn’t. The most useful posts say what you were doing, what you expected, and what happened instead.
Don’t have anything yet that jumped out that needs immediate improving, just wanted to chime in to say I really like these changes!
Having the parameter cards as an addition to the previous implementation of the tools and not replacing the way it was done before is the right direction I think. :+1:
The last release and your (and other staff) posts over the last few weeks about what is coming seem to have completely transformed the “vibe” in this forum, it seems like out of nowhere, both development and transparency has ramped up, and it’s really nice to behold!
Thank you!
Just the beginning, we should do even better.
Thanks @daniel.crk! We will elevate this even further.
@tibi_Shapr3D What are the plan for roll out to the masses?? And have you considered doing a public beta release, like you did with HBPM??? Currently, it’s almost like the release version, is becoming a beta test. You even marked the Fill tool as beta…
In the previous thread on PMCards, @tibi_Shapr3D asked for wishes. If not too late, here’s mine:
MCP interface. So integration with the big LLM’s for modeling.
Once they learn how to do proper constrained sketches here in a few months, AI will be a must for a CAD package… But with Istvan’s Neumann project, I assume you are more than aware of that. I just hope you won’t leave it up to Neumann or just try to train your own models for this.
If your changes behind the scene to make better/quicker tools is anything like OnShapes FeatureScript please consider opening that up to uses. Doing this text->code->CAD they showcases, seems super powerfull.
And along those line. An appstore for sharing custom extensions would be very useful too. That way the slot and hole features would have been made by the community long time ago.
Speaking of Hole feature. Please consider adding an option to make them 3D printable without supports. Both horizontal and vertical. So either a teardrop with flat top and for bores, a incremental build up like this
we are working on it. Can’t tell exactly when, but it’s coming.
We’ve been user-testing Parameter Cards for several months, including with the Gamma group since June 12. We haven’t run a public beta similar to HBPM because the nature of this change is fundamentally different.
UX changes like this have a much broader impact on existing users, particularly because people have established workflows and muscle memory. That’s why we’ve been user testing and refining the experience over an extended period.
This is also just the foundation. We’re planning to release a substantial set of new features and improvements built on top of Parameter Cards, so there’s a bigger picture to this change than what’s visible today.
Fillet Tool will not work with when using the Centered Rectangle Tool, if it resized to desired dimensions, there is an error message about constraints and I cannot find the constraints to remove. If I apply the fillet tool before resizing, the result is no longer centered.
That’s exactly why I would have thought a public beta made sense. Not knowing if the selected few have the option to turn it on/off…
Either way, it’s your call. I guess I’m just bummed I don’t get to try it yet… If you hadn’t announced it publicy, before it is actually ready to go public, then we would know what we’re missing… :slight_smile:
Very curious to see how this develops. If i could somehow connect my Shapr projects to Fusion 360 CAM through some sort of MCP type bridge that would be sick
That would probably have to be with your favorite LLM in between… So it talks to both MCP’s
But with the way people can “vibe code” today**, it can’t be long before Shapr has CAM too… Or before a LLM can generate G-code directly
**Have a look at what Stefan from CNC Kitchen has made. One man, 2 weeks and you basiclly have a complete CAD suite. Plus all the 3D scan tools. That’s just crazy
Exactly, i already have claude connected to Fusion 360. It’s a pain when a file is updated to have to re upload it assuming its anything beyond a minimal update. Would be nice if claude could auto sync the files between shapr and fusion
Rectangles (and polygons) are special sketch objects. Applying the Fillet Tool converts them into regular geometry, causing them to lose their special properties, including the centered behavior.
We’re discussing several ways to improve workflows like this. One possibility would be to automatically add construction lines and constraints so that a rounded rectangle retains behavior similar to that of a Centered Rectangle.
What would you expect the ideal outcome to be?
Hello Axos,
Thank you for your response, for me having automatically added construction lines would be great.
Regards
Jan
Would have to be some way that maintain the parametricity. So the center location and size can be changed with variables. Otherwise this feature quickly becomes useles.
Have you considered sort of a mini-parametric card for some of the more “complex” sketch items? Like “text”, patterns and mirrors. And a rectangle, so you can specify each corners radius.
Maybe not as a separate popup, but a way to give them more variables, that are easily accesable/editable.
