Parametric Copy distance as a variable?
So, I have made one item with parametric dimensions, width and height. It’s the one near the origin fwiw. Then I copied them, moving the distance needed. And I’d like to have this distance as a parametric variable. Is this possible using the copy method? -thanks
OR, how do I do this? -the easy-est way…
Hey, I kinda figured it out. If you make the rectangle, copy it, it stays a paraMet, then make a line, make it a construction, and make the length a var. Also the line it to the center point of the rect. Presto!
