Parts Disappearing from Design
So when I export this file - which, for some reason, is 1.33GB - as an STL so I can print it, the freaking wheels disappear!
I don’t know if it matters but most of this is not unioned. This was deliberate so I can keep the components free to make sure they will align to an existing part after printing.
I assume you imported the model and deleted parts you don’t want for 3d print.
Usually happens when your model is not solid or normals needs to be flipped.
Why would you assume that? I didn’t deliberately delete anything.
Imported models sometimes are not solid or normals need to be flipped?
