I have a component with many (~500) objects neatly organized in a folder (with some subfolders). When I make a linear pattern from this folder (7 copies), the resulting object is a single folder with 3500 objects inside, flattened out, and with none of the names I had assigned to things in the original copy. As a result, I really can’t use this feature, unless I am missing something. If not, it seems like something that could be addressed without too much difficulty: duplicating the object (folder) tree for patterns.
Related topics
| Topic | Replies | Views | Activity | |
| Not appending (1) on nested copied objects in folders | 2 | 385 | July 18, 2023 | |
| Duplicating folders | 6 | 987 | October 25, 2024 | |
| Copy not working with patterns | 2 | 241 | May 8, 2023 | |
| Basic Folder Duplication Option within item menu | 0 | 54 | March 10, 2025 | |
| Making a separate copy | 3 | 807 | August 17, 2019 |
