Hello! I recently had a problem with resizing cylindrical surfaces. Previously, when I clicked on a cylindrical body or radius, its size was visible and I could change it. But recently this opportunity disappeared. Now when you click on a cylinder or radius, zero is shown and you can no longer set the size. Now you can only set an offset relative to an existing dimension.
Are you sure it’s a cylinder, and not an elliptical shape? Bodies created from ellipses don’t have a diameter to show.
in previous versions of shapr everything worked correctly. But recently such a problem appeared in the latest version of the program.
It’s a cylinder
Please open a support ticket here https://support.shapr3d.com/hc/en-us/requests/new, we are happy to check what the problem might be.
