Looking to create an example pattern like the following but I’m having troubling figuring out the best way to do it. You can see that it’s a uniform pattern all the way around and its a shape that doesn’t allow emboss and wrap. Anyone have experience or guidance as to how they would proceed to do this?
So. Make the coke bottle shape. Duplicate and set it aside for now. Then draw a very thin rectangle at the bottom of the copied bottle and revolve that into a 360 degree spiral shape as tall as the bottle. Intersect that with the copied bottle.
If you project the swirly bodies to the bottle, then hide them, that will give you intersections for the circelly bits. New word for the day: Circelly. Also Roundy.
Which reminds me. you can make a plane, move it to the side a bit and project the bottle to the plane. Cool stuff. Useful if you keep track of the plane distance moved…
