Projecting a hole from one body to another
Hey all. I have a cylinder that’s hollow with 7.5mm walls. I have some holes on the top that are for heated inserts. The cap of the cylinder has holes as well to run bolts through. The floor of the cylinder has pockets on the bottom that aren’t 3d printing properly. I split the body at the bottom but don’t know how to project the holes from the cylinder down to the bottom so I can attach them again. Any help would be huge. The holes on the cylinder walls need to stay at the same depth, I just need to project location down to the bottom body. Thanks.
Simply selecting the top edge of the hole and projecting it the the desired face should work?
Oh crud. That was really quite easy. Thank you
