I’m just learning so there may be a better way to accomplish this. I’ve created a sketch that I want to create a pattern of for the sides a cylinder. To do this I created the sketch, copied it by using rotate around axis, then tried to project onto the cylinder. The sketches that were on the from turned out right, when I rotate the cylinder though, the sketches on the backside are all messed up.
Here’s a short video of what I’m talking about.
Is there a better way to do this? If not, what am I doing wrong causing the distortion on the sketches?
