Wrap a sketch to a cylinder
Is there a way to wrap these logo to a cylinder?
Hi @JMIRAND Welcome to the Forum :sunglasses:
Use Tools > Project
There is an example of this at:
https://discourse.shapr3d.com/t/flat-to-round/6081/2
if you need further help just shout.
Happy S3Ding :sunglasses:
Projecting is a vital feature, but unfortunately will warp the logo in this instance. How can we wrap these shapes onto the cylinder or curve?
Hi @quartzstudio Welcome to the Forum
Create the Logo and use Transform > Rotate around Axis
Then use Tools > Project:
Thanks for your reply! Unfortunately, this method still causes warping. The edges of the A in this example will be stretched (just a bit), but these irregularities split among the many characters and shapes of a logo distort the original artwork.
Is there any way to wrap a shape around a curve?
(not just splitting the source artwork and projecting smaller shapes and hoping no one will notice the distorition)
@quartzstudio
The A size was deliberately chosen to display differences between Original and projection.
the following illustrates those differences:
The dimension difference of the Top Cross Bars is 17,569mm - 17.500mm = 0.069mm longer on Projection
In the following the A has been Scale to 25%:
The dimension difference of the Top Cross Bars is 4.375mm - 4.383mm = 0.008mm
Click on the images to verify the Dimensions at the bottom centre.
In this example, I extruded the logo much deeper than required, cut of front and back at desired diameter.
