Hi there, I struggle redesigning the step I sent. Could someone show/explain how to design it in shapr3D? thank you in advance.
Loft between a large circle and a small circle. Use the shell feature choosing both ends. On a plane sketch the side profile to cut the profile shape. Then select and edge, add a plane on a point. Sketch a shape on the plane to kerf the angled edges using the sweep tool on both edges.
It used to be that the sweep cut by default. Now it makes a new body. I find I am constantly have to relearn this program.
thank you very much! and on the top face you would create a new plane with the same profile and subtract with the sweep tool?
Since I start using S3D sweep creates new body.
What for? I showed on a video how to create the form from the photo. If you need anything else describe or better show us ![]()
