Rename : c'mon
Is there a problem with the “rename” function since the last update or is it just me?
Thanks for reporting, we are investigating the problem!
In the meantime, you can use Dark mode where the text color is correct.
Hi Laci,
On the iPad the text looks fine in light mode. In Dark mode it work, but there is not much contrast of the selected text background to the black. It is a little difficult to see what is selected.
We have identified the issue, it’s only affecting Windows, and we will release a hotfix for it tomorrow.
Thank You !
Fix is out, you can update from Microsoft store from the Library page and check for updates, or from our website if you used that installer. Thanks for the patience!
Update in progress…
