When I am sketching, at least 1 extruded piece seems to always end up above the vertical base. When a piece is higher than others, it has trouble printing with the others. I can use “front” view to visually lower the object to what I think is the base, but it isn’t always actually flat.
Is there a way to select an object and make it rest at z=0 ?
Joe
