Sample
Continuing the discussion from Screw like or threaded part:
Hi there,
I am new to this forum, this being my first appearance as a Shapr3D user.
The video shows the making of a non tapered thread.
It lacks the possibility to accurately set the defined number of threads per inch (TPI) making the tread more for show.
I have tried more or less successfully to produce an inner thread 1/2”.
A 1/2” thread has 13 or 14 treads an inch normally depending on the kind of thread used. I used the following numbers to get to my result,
Angle 4680, height 25.4.
The NPT, tapered thread is a feature I would suggest to implement.
But taking in to consideration that Shapr3D is not a full featured CAD program, I’ll take what is available as features.
Added the final result,
Thank you, Carel.
I am now also developing a portable beverage mug on Shapr3d, and it is the first product I decide to develop it on this platform,I want to say your issue is also the only problem I come across during my design,maybe I will export it,and build it on Creo or sth.
Hi one,
Do you need a tapered thread? You can do it with a straight thread I think :thinking:?
Good luck with your design.
:hourglass_flowing_sand:=:small_airplane:
–Certified Virus Free by 4SecureMail.com ICSA-Certified Scanner–
Hi Carel,
I do not need a tapered thread,
I need a standard ISO thread,
but I still did not figure out how to do.:grin:
tks.
ONE
I can help you out with that, at least to get started, I will make some samples to explain the how to.
Try to find the ISO tables that show the thread measurements, that if you want to be accurate.
Give me a day and I will send the samples with the explanations.
Regards Carel.
Hi,Carel,
Thanks for your agreeable,In the first I did not know it could,
After your hit I search the manual, and figure out the method, but thank you all the same
