Having trouble with selecting parts of my model, it takes loads of clicks.
- Is there a way to select the faces ( not the outlines ) in a folder / group.
and - Is there a way to group sketches on the same plane, so you can easily select a group of lines on a sketch plane.
In the model I have to click on each face 24 times and then the inner 24 times and then the core 1, that is 50 clicks, i just want to select all the faces in the sketch plane to extrude them.
PS: I tried removing some of the lines but they would not delete, after I did this I also needed to merge all the extrusions.
