Hi. First time use it. So, How to set the midpoint on the circle. In the video when you are drawing a circle. It’s already there. But I get only one central point.
Which is this video?
Thanks for quick reply. A point on string so you could pick and change the size
Oh, I see! We removed that point since the version 3.3, now you should select the circle itself and drag it to set the radius of an existing circle. We will update the video soon, thanks for the report.
