I made 3 sketches.But only the circle could work under shell tool. Any constraints on tool application?
You should try it with a smaller thickness. It works for me:
By the way, you can check the maximum possible thickness with the offset tool (you can drag the edge until the maximum allowed thickness is reached):
Thank you for fast reply.
