Short Cut 'E' does not cycle Extrude types
Hi Shapr Team.
Is there any chance you can fix the letter short cut for ‘E’ EXTRUDE.
Most of the other letter short cuts work and cycle through the drawing options.
For example ‘R’ cycles through all three Rectangle options.
‘E’ does not cycle, you only get Single Extrude and not Symmetrical extrude.
This should be an easy fix in the code, and will save the users having to select the Symmetrical option from the sub menu.
kind regards.
hey, we fixed this when introducing parameter cards. Let us know if you’re missing this cycling functionality in any of the tools now.
