The problem that this feature will solve: Trying to click a tiny button.
I would love to be able to while extruding etc, to e able to hit U, N, S, or I so that I don’t have to click a tiny button next to the arrows. This would speed up workflow.
Faster extrudes.
It’s a challenge finding the tiny options button to then select a type.
Is this a workflow blocker for you? Is this why you can’t use Shapr3D for work? Is this slowing you down? Yes, slows me down.
