Cycle through features with same shortcut key
You guys have a great feature built into the interface whereby pressing the same shortcut key goes through the various choices of a feature. For example, if I press the F key I get round fillet, and if I press the F key one more time then I get chamfer. Similarly if I press the S key for scale, it cycles every time I press the S key.
But the programmers did not do this for all the other choices.
I would love to see this also for:
-Offset cycle
-Extrude
-Offset
In the Sketch I would like to see:
-Spline
-Rectangle
-Offset
-Pattern
-Polygon
These little things all make the experience better for efficiency
thanks
