Slow & laggy
I have a macbook pro m3 max. But this app is lagging when my drawings get semi complex. I really love the simplicity of the program but its been hell working on shapr. Are there settings or something I can do to make things faster?
Hi Abe,
You could try closing all other apps when your drawing becomes slow and sluggish. I have also closed the app, then restarted, which seems to help.
Drawings with large amounts of sketches causes sluggishness. The more you reduce the lines, dots, (sketches) the better the app works.
I’m running a MBP on an Intel i9 with 16gb of ram and 4gb GPU. I also bought an external 4gb GPU to help. Without the external GPU the MBP becomes really sluggish in large sized drawings.*M series chips will not work with external GPU’s.
What size GPU are you having in your M3 max, 30 core? Looks like thats the smallest size you can buy. You would think this would be more than enough?
If you have sketches which don’t have to be on the same plane, it’s best if you separate them into multiple sketches, e.g. create a construction plane and offset it a bit from the default plane. It will help a lot.
We also have plans to improve sketching further once the parametric version is out.
I will put this out there that when I give mac specs, i have trouble understanding apple’s new architecture with regards to their processors and so on.
its 40 core with 32g ram, its a 6000$ laptop lol. ive run very complex graphical works on this laptop no problem but then I get to shapr and it’s just slow. Its definately a software problem, not hardware. Probably my fault for jumping the gun and purchasing a full year without really testing it’s capabilities.
Can you share a problematic design?
have the same problem in many files, and it’s very frustrating. This all started with the updates to parametric design. I loved the simplicity of Shapr3D, but now it’s extremely frustrating. Even a simple object move takes forever. I have a Mac Studio with an Apple M2 Max, and I do a lot of work on this PC without any issues; it’s only Shapr3D that is slow and laggy.
Hello,
Have you try to reboot without extensions (Safe Mode) ?
I had this kind of problem with Illustrator 2025 and it was solved. An extension (widget for setting my screen) made the use of AI impossible. I removed it and everything works as before.
Same exact thing on my iPad… It’s beyond frustrating when it crashes every time you try to open the project. The app shuts down… So, now you’re forced to redo the model because you have a deadline. But after the 4th time of redoing the project and continuing to try to contact someone for help… well yeah it gets frustrating cause you’re paying all this money to send this and email this and……. Yeah it gets annoying
A year on and the same sluggish response.
Is there a schedule foe when multi-core update will be released for the Apple Silicon Macs? Will have to revert to Inventor on Intel chipset as cannot create in real-time with the lag on S3D
Can you all take a look at this SHAPR file. This may be a good example of slow execution. I am trying to merge two geometries; one is extremely complex and the other one is extremely simple. Here is the link… Bowl.shapr
Hi, I’m just trying to open it on my iMac with Core i7 at 3,8GHz and 64GB. The icon is spinning since several minutes now and saying it’s tesselating the body.
CPU usage is only at 100% , meaning that shapr3D is only using a single core for tesselation. That seems to be the bottle neck with complex geometry. The most important value for a snappy experience seems to be the single thread performance.
Could you please submit a ticket on the support portal?
Please include: App version, device specs, screen recording and the .shapr file you are experiencing the issue with
Hi Lys, I just tried to open the file from juanalvareztx - bowl.shapr. I couldn’t open it on my machine within 15 minutes so I gave up. I don’t know what the content of the file is, so there is no use for further support on my side.
maybe you can have a look into the file for youreself?
Best regards
Matthias
