Smaller Manual Rotation Increments
Problem: Rotating in manual mode only allows for 5° increments, which is incredibly frustrating. Tinkercad, for instance, allows you to hold down a suppmental key like Alt or CTRL to allow for more precise control if needed when manually trying to rotate.
Problem this will solve: Having to continually type in rotation increments if one prefers to rotate visually.
Outcome: Saves time-- rotating visually in many cases is much quicker than typing for certain shapes
Is this a workflow blocker for you?:
It slows me down. The options for more manual control --if desired-- is always better. If people want to stick with the 5° increments, they’d have that ability-- but the option for more precise manual control ought to be there as well.
With grid off there are no increments. And you are not locked on to the arrows, extend out as far as your screen allows to get more precision after initiating a rotation.
oh man, thank you so much for that tip! That’s a huge help.
