What happened to Move-Rotate, rotating in 5° snapped increments? Sometimes it rotates smoothly in fractional degrees. Other times it’s back in 5° increments. Personally, I prefer the 5° snapped increments and can always enter exact degrees when necessary. Now with fractional degrees I alway have to key in the desired degree or angle.
The way it always worked for me was when rotating close to the rotation point, I’d get fractional degrees but if I moved the pen out further after tapping and holding on the rotation arrows, I’d get the 5-degree increments.
I can’t get that to work. Moving the Pencil in or out of the rotation arrows has no effect. Can you share a short video of rotating a part both fractional and in 5° increments?
Hi Daniel,
Thank you for the clarification. I thought I was going nuts. Sometimes I turn off snap to grid.
-Mike
Mike, it’s working fine on my iPad. iOS 14.8, latest Shapr3D version.
