Hello please am stuck and i need help, i designed this pegboard of dimension 720mm x 720mm am trying to split the design into 6 different sections of 240mm each, trying to achieve a modular skadis pegboard that has a center piece and joins perfectly well when 3D printed in 240mm, please am stuck and don’t know how to go about splitting it
Think puzzle pieces?
You will need about 0.25 - 0.35 mm tolerance on the out protruding bits to get it to assemble easily.
Apply your slot pattern to that and you could print a whole wall.
