Stealth Press is a highly precise, mostly printed DIY heat set insert tool for generic, TS100/101, and Pinecil soldering irons.
[The introduction of the Dremel Add-On (Printables)] transforms the Stealth Press into a modular platform, enabling users to expand its capabilities by attaching additional tools.
There are multiple projects like this available for free download and build. Most of them rely on Misumi standard 2020 or 4020 extrusions to provide precision which adds extra cost, time, and complexity to the build.
Stealth Press build relies on precision provided by 300mm MGN12H linear rail instead which provides a stable spine to build every other component around it.
Integrated, printable build plate adds another critical element for precision and easiness to work with.
Stealth press uses KEY-BAK key reel with kevlar belt loop to ensure longevity (proven to last more than 1 million pulls) and has some other quirks, features, and QoL improvements compared to similar projects.
More info, BOM & STEP file here: https://www.printables.com/model/609644-stealth-press-heat-set-insert-press
