Hi everyone. New to Shapr and a beginner 3D Printing hobbyist. Does Shapr have the ability to view STEP files without going into an edit mode? So, the Autodesk Viewer allows you to import and open a Model viewer. From there, I can peel back (hiding) layers of the model. Say for instance I want to know what size screw was used, I could click on the screw and the description would be highlighted, ie M3-20 screw. I can access the model viewer in Shapr, but when I click on a part, a screw head, it goes into edit mode. I hope this made sense! Also hope the pic comes through. Thanks!
