Still some issues since 3.60
Alright I’m kind of loosing it here.
I was waiting for the 4.0.0.957 to take care of the problems I have and it doesn’t.
Shapr worked good until the 3.60 when I started having this issue.
I’m on mac mini big sur 11.2.2.
Faces are not turning blue when I click on them witch is something I can work around, problem is when you create e new plane and cannot see it…
Check the video
Hi!
Could you provide the details of your mac? Especially looking for the GPU.
Mac mini (late 2014) 2.6GHz Dual-Core Intel Core i5
Any news??
Our team is investigating the issue, I don’t have exact fix date or conclusion what causes it yet.
:slightly_frowning_face: thank you.
Alright guys it’s been almost a week that I posted about my problem and I’m sure you are working on it but I need a solution. It is impossible to use shapr without seeing my planes. Should I reinstal one of the old version? If yes I will use the new features and then when will my problem be solved? A little bit more fallow up would be really appreciated here. Thanks.
is the issue related to certain designs or any design? Do you have a specific reproduction process or does it happen randomly? If you have any other details about the issue, that would help a lot.
We were able to reproduce the issue, looking into a fix currently. Will keep you updated.
yay!!! where is the upgrade for me to be able to work again???
The update will come out on Monday.
Fix is out, it might take up to 24 hours to reach everyone. Version 4.1.1. Let us know if you have any problems.
