Since the last update on the Ipad, I suddenly can’t select some horizontal faces anymore and I will get the message: Something went wrong, but your design is intact.
If I select a tool and then select the plane, I won’t get the error message
Could you open a suppor ticket, attach the workspace in .shapr format, and a short video? It would help a lot in the investigation.
I’m also having this problem, i opened a support ticket with a video, but will also send shapr file.
It is fixed ![]()
Indeed, it should be okay in 5.311.
