I’ve had a few issues when exporting to STL (both standard and high quality) and OBJ files. So in trying to find out what’s going on I tested a couple of things and here is what I found out…
First test
Cylinder 30mm diameter, 50mm height → Cura slicer imports at 60mm diameter and 50mm height (the height was preserved properly, but size was doubled)
Second test
Cube 50mm x 50mm x 40mm height → Cura slicer imports properly at 50mm x 50mm x 40mm height
I’ve tried this simple shape on a couple of programs and the problem persists with Shapr3D only, something as simple as TinkerCAD exports properly sized Cylinders at the correct size in Cura.
Is this a known bug? I’d like to work on a 3D print design that involves a cylinder and can’t seem to get past this issue.
