Improved experience with folders when navigating the “Home” menu.
Please stop the “Learn” menu in the left-hand navigation pane of the Home Screen from automatically expanding when navigating back to the Home Screen. At the moment, even if I collapse the learn menu before opening a project, after returning to the Home Screen the learn menu is automatically expanded again.
This wasn’t really noticeable before, but now that we have folders, it reduces the number of folders that can be seen by default in the navigation pane.
The app should remember my preference and keep the learn menu collapsed.
I can still achieve everything I need to achieve, but the change would improve the user experience.
It slows me down, because the folder view is reduced and I have to manually close the learn menu every time I go to the Home Screen.
