On TRANSFORM I’m trying to move and it’s gone extruded and stuck
Last half an hour … any clues please ?
Carl
It’s hard to tell what’s the problem from a picture. You can restart the app, and you won’t lose data, don’t worry.
Re start … how do I do this ?
Transform tool problem
Press the home button twice, and swipe up the app.
Hi i’m Really struggling eith this drawing now it’s stuck and won’t load
Carl
It should finish loading, even if it takes a lot of time. When it finished, can you share the workspace file in .shapr format? Then we can debug the issue.
Hi Istvan
Did you see the problem I have with the page not loading ?
Carl
Hi Carl,
would you be able to access these files by connecting your iPad to your Desktop computer, open iTunes and copy if from the Shapr3D there.
Here is a little help here: https://support.apple.com/en-bh/ht201593
Happy to take a look at the problem - we just need to see the files
Daniel
It’s loaded and I have done what I needed to do
Thanks for the contact …appreciate it
Carl
Hi Carl - good news.
If you ever run into a problem like this again, just send us the saved workspace(following the above method) to support@shapr3d.com.
