Subtract method - Boolean operation failed
Greetings to the community, thank you for it!
I’m trying to modify the model and put holes in it. The beginning was good but now I can’t do it even after smaller quantities, not even one piece can be subtracted using the subtract method.
Boolean operation failed…
Thanks a lot for your help.
Hi @3ASYPRINT, Boolean tools fail regularly because of the following two cases, please check if they are valid for your model:
  • There is no intersection between the bodies
  • There are overlapping faces instead of intersecting bodies
If you are not sure what can be the problem, please feel free to send us the file by opening a ticket using this link:
