Boolean failed at substraction
Hello everyone,
I just got the app and learning it little by little.
I was following a guide on how to design a soy sauce bottle until I came across this problem. I must be doing something wrong but I don’t understand what exactly.
I was tying to subtract the top round plate and it was giving me that error.
Hi @Eugene,
Can you please share or upload the Shapr3D design?
Here,
Thanks for sending the link, but that is just a preview. Please send us the Shapr3D design, which would allow us to check if there are any intersections between the bodies for the boolean.
I saved the design on my IPad. When I try to attach to this message it says ‘New users cannot upload attachements.”
I just updated your user level, please upload the file
Thank you. Here you go:
Bottle.shapr (23.6 KB)
It seems you are right Eugene. The two parts definitely intersect, but neither will subtract from the other.
I tried Intersect as well, but that didn’t work either.
I agree, the subtract failed.
While the Shapr3D tech are looking into it, here’s a quick workaround. Use Split Body.
Yep, thank you
Good one Mike, well done :clap:
Thanks for sharing the workaround @TigerMike
@Eugene, can you please confirm that you did this tutorial? We have to check this particular model in a bit more detail, please go with Mike’s workaround for this time
I didn’t make that tutorial. I followed that tutorial to learn.
