New user here. I have a simple test case (see attached screen shot). I’ve been wrestling with the SVG export - trying to get data that matches what is in Shapr3D.
I figured out that to get exported values that match the mm (1 mm grid size in Shape) that I need to use a DPI of 25.4 (number of mm in an inch). However, while the UI suggests (clear the text field to see) I can use a fractional number; you cannot. It rounds it down.
That causes issues with numerical values in the export file (see attached svg - you can open it as text).
Relatively speaking it is all correct - it’s just scaled and offset from where it was originally created.
Is there anyway to get a text readable format out of this software that matches the values in Shapr3D?
