Is there a way to use the loft tool with a spline like a sweep tool. It would be a sweep with multiple sketches. The loft tool does not conform to a line. Example ring, you make multiple sketches and use the loft tool it does not conform to the circle for the ring size. As it stands you can only make one shape from a sweep tool. It would be great to be able to select multiple sketches in a sweep tool.
Only closed profiles can be lofted, but thry can contain splines of course.
@eeek
Use Add > Construction Plane then choose the option Perpendicular to Curve at Point
Drag the ‘Point’ to the position on the Curve, Spline, Line,…
Sketch as many Closed Shapes as required:
Select the Closed Shapes and Sweep:
