Sync Conflicts
I’ve turned on sync yesterday. Now I see some drawings have a conflict. I mostly only iPad to edit my drawings and just use my Mac to view them. How do I clear this conflict. If I delete on the Mac will it delete on the iPad?
Click on the design, and it will bring up the conflict resolution modal, where you can select what do you want to keep and what do you want to be gone.
Even camera position is synced (so you can continue work from the same position), meaning if you rotate the model on mac while it’s open on iPad, and you change / move the camera on iPad too, it will cause a conflict.
