Text Import
Hello Team Sharpr,
I understand, that you are working on a text feature. Is there any idear for a work around on the ipad? creating a svg file with text in any ipad app, convert it to a sharpr import format, and then use this importet text in sharpr? if so, which ipad apps i will need? thanks, mery xmas!
Hi, we currently don’t support text import. We will support it in the future, but until then: What I usually do in these situations is tracing. I import it as a photo, and sketch over it, longer process, but with same results.
Thank You!
Long long process… any alternative? I’m not good enough to draw
