Morning,
After the latest update, it seems that the text is on the different side. Normally when selecting a plane the text is directly readable. Is this correct ?
Since you are in 3D space, you can look at it from this direction, and the other direction. If you look at it from the back it will be reversed.
I see what you mean. So for new text the direction is broken in some cases. We’re looking into this, thanks for reporting it.
