Hi, I am having a problem with the Transform->Move tool in that I am trying to move and copy an object but am unable to get more than 0.7mm away from original object before it disappears. Once moved I can select and start to move 2nd object but then it disappears. I have used search for similar questions/bugs but haven’t found anything. I have also try the Tanslate tool with same disappearance of object. This object is in a group if that makes a difference.
Help would be appreciated.
Tom
Thx a lot
