Trouble extracting or moving a design
I am having trouble with turning a sketch into 3D. It looks to be a closed sketch but has trouble adding the top line in the design. No matter what I do, it remains dark.
Exit Sketch mode and try again.
Tried that many times — no difference. I thought a joining point might be not quite touching but appears to join on both sides when I zoom in as far as I can.
If it’s not too much trouble, can you upload the Shapr3D file to the forum?
Many of us would like to help out.
Slicing the sketch is usually a good way to find holes. If you use straight lines, when the sketch filling appears, that part is okay, just repeat it until you find the hole.
Laci_K, thanks for that tip will try it.
TigerMike, thanks for the offer but not with this particular sketch. I was attempting to copy a design I already drew on paper that’s too important to share. I’m planning to ask another question soon and will draw something specifically for it.
I totally understand.
FWIW, one thing you can do is make a duplicate Shapr3D file and delete everything except for that particular sketch in question. Then you can share that particular issue and only that issue.
