Trouble printing text as different colour after export
Hi
Newbie here. I’ve made a disc. Extruded some text, and imported into Bamboo Studio.
Now I see there are some problems with color information in such things a STL files. But it would appear that the STL file sees both the disc and text as part of the body.
Is this standard? or what have a stuffed up?
You can modify this behavior by changing the Result parameter to New Body in your history tab.
After that, just reimport the file into Bamboo Studio.
You should shy away from stl. Use step instead. Or at least use 3mf.
