Here’s I’m extruding an addition to a simple body. If I recall, it used to be that the result was a union and one would have to select New Body, Intersect or Subtract from the gizmo if needed. That no longer is the case. It also does not work when selecting Union from the gizmo. I have to go to Tools, select Union then select all 3 bodies. Is this a design change?
Same here Mike. Seems like a bug if you can’t even select union and have it union.
I recall a post about this where it was intentional. There was no explanation why the Union option is still available during extrusion.
I’ve experienced this recently and thought it wasn’t working because I was updating a year old model.
